What is the lower frequency signal generated from HR Timer?
Nsg1987
I am able to generate PWM frequency of 640 Hz using HR Timer. Now I want to generate the same with 100 Hz. I tried to manage clock prescaler but found no success.
Diane POMABIA
Hi @Nsg1987​
Can you precise STM32 that you're using ?
Diane
Hi @Diane POMABIA​
I am using STM32G474VBTx.
Nikhil
Hi @Nsg1987​
You can refer to AN4539 that will give you more detail about HR Timer feature :
https://www.st.com/resource/en/application_note/an4539-hrtim-cookbook-stmicroelectronics.pdf
DianeP
