What is the lower frequency signal generated from HR Timer?
2023-05-23 3:56 AM
I am able to generate PWM frequency of 640 Hz using HR Timer. Now I want to generate the same with 100 Hz. I tried to manage clock prescaler but found no success.
- Labels:
HRTIM
STM32G4 Series
TIM
2023-05-26 7:18 AM
Hi @Nsg1987
Can you precise STM32 that you're using ?
Diane
2023-05-28 8:29 PM
Hi @Diane POMABIA
I am using STM32G474VBTx.
Regards,
Nikhil
2023-05-30 2:08 AM
Hi @Nsg1987
You can refer to AN4539 that will give you more detail about HR Timer feature :
https://www.st.com/resource/en/application_note/an4539-hrtim-cookbook-stmicroelectronics.pdf
DianeP
