We use STM32F407VET6 TQFP100 At the Moment we use the Step 4 of this Controller. But now we have Problems with the I2C-Bus. Can you send me an errata Sheet About the changes from Step 2 to Step 4. In the datasheets there is not enough Information.
SSpoh.1
Are you aware of ST problems with this Step 4 version.
We think, that the driver can not go to Low Level
6 REPLIES 6
Amel NASRI
Hi @SSpoh.1​ ,
What do you mean by "step"? Do you mean that you are migrating from STM32F2 to STM32F4?
These are not steps, but different families of STM32 microcontroller.
-Amel
Stepping is the common term to describe the version/revision of silicon, and mask sets related to the IC
ie REVID within DBGMCU IDCODE
Hello Amel,
we use the Controller STM32F407VET6 TQFP100
But there are diffferent Versions (step)
At the Moment we use Version (step) 4
In the past we use Version (step) 2
[cid:image001.png@01D62D2B.01C06D00]
Can you send me an errata Sheet about the changes from Step 2 to Step 4. In the datasheets there is not enough Information.
Stefan
Need to fix the image attachment.
If the Errata attached to previous post is not sufficient you'd likely want to get with the FAE supporting your account to get some better understanding/translation of the issue.
Did you take an old working board with v2 chip and physically replaced for v4, and the problem appeared?
If not, why do you think you have problem with a particular version of the chip?
