2021-06-06 6:55 AM
Hi
I use 16-bit ADC of STM32H725 with an external 3v reference.
what is the current consumption from the Vref?
in the datasheet DS13311 - Resources - Search STMicrocontrollers
table 83 the current consumption is only from VDDA.
2021-06-11 3:41 AM
Hello @IMor.1 ,
Which chip revision used ?
Which mode used : SE (Single Ended) or Differential Mode ?
Please provide more details, so I can check back the value of your use case with the Design team.
Imen
