VCP for STM32F3
Posted on February 21, 2018 at 14:09
I'm trying to implement Virtual Com Port on STM32F3. I use IAR.
I've included all files from a demo project.
However I have numerous errors while compiling the project. Struggling for hours I came to this question
Is there any compiled project with VCP for STM32F3?
Note: this post was migrated and contained many threaded conversations, some content may be missing.
57 REPLIES 57
Andrew Neil
Evangelist III
Posted on February 22, 2018 at 11:45
MY DEAR LORD!!!
IS THERE ANY ADEQUATE PERSON ON THE FORUM UNDERSTANDING ME???
Posted on February 22, 2018 at 11:12
Neil.Andrew wrote:
Hugely
more effort is required in getting the USB stack working!!!
As demonstrated in the OP's previous thread:
https://community.st.com/0D50X00009XkfBRSAZ
Posted on February 22, 2018 at 11:22
Right, you need to understand USB callback when receiving data from the USB, need to take care of unfinished transmit to make transmit reliably. A lot of stuff. That's why I promoted ST-LINK Virtual COM.
Posted on February 22, 2018 at 11:47
You seem to be the one failing to understand.
As has been explained a number of times, there are two possible ways to have a 'VCP' on a Nucleo or Discovery board.
You have not yet clarified which particular 'VCP' option you require.
So, please answer the simple question: Is using the VCP provided by the ST-Link sufficient for you?
Posted on February 22, 2018 at 12:01
Provided by the ST-LINK??? How ST-LINK involved here?
I have STM32F3DISCOVERY BOARD (MB1035B)
I debug/program on USB-LINK connector. And VCP communication I what to run on USB USER connector.
A piece of the demo code
while ( 1 ) {
        if (bDeviceState == CONFIGURED)
            STM_EVAL_LEDOn(LED6);
            CDC_Receive_DATA();
            /* Check to see if we have data yet */
            if (Receive_length  != 0)
                STM_EVAL_LEDOn(LED4);
                int i;
                for (i = 0; i < Receive_length; i++) {
                    localBuffer[i] = Receive_Buffer[i];
                CDC_Send_DATA(localBuffer, Receive_length);
                Receive_length = 0;
The problem I can not compile the demo so I want to see compiled example for IAR.
Jesus Christ
! What I'm asking? NASA project?
Posted on February 22, 2018 at 12:10
Stay calm. It's a user forum, the voluntary one. You are trying in this piece of code USB/CDC. Not the ST_LINK
Posted on February 22, 2018 at 12:14
For goodness sake - have you not read any of the replies in this thread??
Look again at this picture:
There is no target software at all required to use the ST-Link's VCP connection - as far as the target STM32 is concerned, it is just a UART connection.
This is by far the simplest way to get a VCP connection from a Nucleo or Discovery board to a PC.
So, again, why can you not simply use the VCP provided by the ST-Link??
Posted on February 22, 2018 at 12:16
The B version of the board probably does not have the Virtual COM emulated by the ST_link so you have no choice and need to use USB/CDC.
Posted on February 22, 2018 at 12:18
Or use a different board.
Or use a separate USB-to-UART converter; eg,
http://www.ftdichip.com/Images/TTL232RRPI%201_a.jpg
