User timer interrupt for capture multiple time
‎2024-06-05 5:29 AM
Hi all,
I'm working with STM32F4 discovery board, and I'd like to know if I can use one timer with interrupt to capture multiple time.
For example I'd like to use TIM16, and be able to check 4 times : 150ms, 250ms, 500ms and 1000ms is it possible? After some researches I think I have to use `CNT` value. But how can I know if the time ellasped is 500ms for example ?
I've already do something like this in my while loop, it's working but I'd like to do thaht in an interrupt
// If enough time has passed (1 second), toggle LED and get new timestamp
if (__HAL_TIM_GET_COUNTER(&htim16) - timer_val >= 10000)
HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
timer_val = __HAL_TIM_GET_COUNTER(&htim16);
- Labels:
STM32F4 Series
‎2024-06-15 4:25 AM
One suggestion is to have the basic timer with say 10ms , keep one count incremented, when it reach 15, 25,50 etc you can do the necessary action.
Eg if(count%15 ==0) means 150,300,450 etc..
‎2024-06-05 6:18 AM
Hello @SBaro.11,
Think of using output compare to indicate when a period of time has elapsed to generate interrupts at different time intervals
Enable interrupts and implement ISR for each OC channel
‎2024-06-05 6:20 AM
Thanks @Sarra.S do you an example somewhere ?
‎2024-06-15 4:25 AM
