2023-09-11 2:37 AM
Hi ,
I am using STM32L072CBT6 for my project. We have to use USB for configuration purpose. The controller VDD is connected to 1.8V power supply, but the VDD_USB is 3.3V. Is there any issue to connect 2 different powers ?
2023-09-11 2:53 AM
You will have no problem with VDD=1.8V and VDD_USB=3.3V. In the data sheet, table 23, it says in footnote 3:
[...] VDD_USB is independent from VDD and VDDA: its value does not need to respect this rule. (i.e. max 300mV between any VDDx and VDDA pins do not apply for VDD_USB)
Hope that answers your question?
Good luck!
/Peter
2023-09-11 2:53 AM
Good luck!
/Peter
