USB_HOST_MSC
‎2024-06-11 5:50 AM
Dear Sir/Madam,
I have already implemented the usb host mass storage class project which mainly mounts the usb disk & writes some data to a given file. But this application is not working. Only usb unmout case is executing even though I am inserting the usb disk.
I am attaching the project files ,please check & reply me as soon as possible.
Software development environment - STM32cubeide
evaluation kit - stm32f401vc discovery kit
STM32F4 Series
USB
‎2024-07-04 10:45 PM
Yes it is currently working. The problem was in the vbus.I had forgotten to configure vbus.
Thanks & Regards
Satyabrata Senapati
‎2024-07-04 11:30 AM
Hi @ssena.1514
Did you check the provided examples for MSC and having issue while enumerating the flash disk?
Did you should check the protocol level using for example Wireshark?
Thanks & Regards
Satyabrata Senapati
