UART works on terminal but not getting output on pins of Nucleo board
‎2020-11-09 3:55 PM
I followed the UART example (https://wiki.st.com/stm32mcu/wiki/STM32StepByStep:Step3_Introduction_to_the_UART) and implemented it on a STM32F051 Discovery kit and on a STM32F446 Nucleo board with pretty much identical settings from CubeMX.
If I scope the STM32F051 I get a TX2 signal out of pin PA2 as expected. If I do the same on the STM32F446 I get nothing. Interestingly I get normal output out of the STM32F446 using Tera Term over USB but if I do the same with STM32F051 I get nothing on terminal.
Any ideas please?
- Labels:
STM32F0 Series
STM32F4 Series
UART-USART
‎2020-11-09 7:55 PM
Check the schematic for solder-bridge options to route to VCP vs Arduino header vs pin headers.
‎2020-11-09 4:43 PM
If the signal makes it to the PC, it has to exist on the pins, otherwise how is it getting there? Make sure you're scoping the right pins.
‎2020-11-09 7:55 PM
‎2020-11-10 1:28 PM
That did it. Thank you clive!
‎2020-11-10 1:45 PM
Hopefully this will help someone else. After following clive1's suggestion, I found this in the documentation regarding USART and solder bridges. That's what I did in the picture at bottom and everything works as I wished before. This was not in my radar, so better double check documentation next time. Thank you!
De-soldered 0 ohm resistor between SB13 and SB14 (red circle). Soldered bridges SB62 and SB63 (green).
