TCP/IP - Ethernet
Gokul_Sarvanakumar_60
Hi all ,
Im facing a issue in TCP/IP - Ethernet using LWIP on STM32H723ZGT6 [NUCLEO - H723ZG] , that i gave completed ethernet configuration , ping is good , wrote a tcp_echoserver and modified with my desired outputs , everything was a woking upto a certain level, and i cant RX and Tx and fall into hard fault (Added a Video of the output). I'll add the code file as a zip.
Kindly help me to resolve ii.
Thank You!!!.....
0 REPLIES 0
