2024-07-15 02:54 AM
Hello ,
We are encountering an issue with the USART_DMA interrupt method on the STM32G070CBT6 microcontroller. The problem is that data is only received after performing a hardware reset. We expect the data to be received continuously without needing to reset the microcontroller.
Please suggest the possible solutions.
Thank You,
2024-07-15 04:09 AM
For that you need to share your code to let others help you efficiently. Please use </> button to copy paste your code.
Thank you.
