UART CONNECTIONS ON STM32H7B3I-DK
‎2020-10-24 5:32 PM
Hi Team
I have a DEVICE that provides me data via UART
so i initially thought i can receive teh data to aurdino and send from arduino to STM32H7B3I-DK
However i feel its not convinent to do this
I want to connect the UART device that sends the data and receive on STM32H7B3I-DK board Is this possible
if so what pins are exposed for me to receive the data
Can i directly connect the TX RX and GND (UART) of my device to Arduino pins of Arduino shield on my STM32H7B3I-DK
Approach one
DATA DEVICE UART ---------------->ARDUINO BOARD------------------------->STM32H7B3I-DK
I find issue here, as i connect the UART DEVICE TO ARDUINO I read the data on TX D0 RX D1 pin
I am not sure how can i take another from ARDUINO to STM32H7B3I-DK
DATA DEVICE UART -------------------------------------->STM32H7B3I-DK(ARDUINO PORT)
Is this the correct approach to to this
Summarzing My ultimate goal is to get data from mu UART DATA DEVICE and receive on STM32H7B3I-DK
so can i connect the UART DEVICE TX RX AND GN to STM32H7B3I-DK ARDUINO PORTS
will this Work
Thank you
Deepak R
STM32H7 Series
UART-USART
‎2020-10-25 4:54 AM
If the device outputs 3V3 CMOS level​ serial data you should connect it directly. I don't see the value of involving the Arduino, and any software could be ported to the STM32 platform.
The primary interface opertunities ​are the sheild connection, along with PMOD, CAMERA or other interface headers as provided.
‎2020-10-25 4:10 PM
Hi clive
I hope the Device outputs 3v3 Volts level serial data I am able to receive the Data on Arduino without any issue.
I hope the same levels are used on the STM32H7B31-DK Arduino shield as well and will work
Thnak you
Deepak R
‎2020-10-25 5:59 PM
Hopefully the device in question is reasonable well documented and you can just test it.
