Trying to write 16 bits to a LCD via STM32H7 FMC memory controller end up in 4x16 bits write strobe [solved]
Microman
I'm trying to write to a single register of a LCD controller using the 16 Bit FMC peripheral in SRAM mode.
[update)
My assumption at the moment is that the controller writes 64 bits even the command STRH should only write a half word (16 bits).
When writing one single 16 bit word, the STM32H750VBT generates two #WR strobes within two #CS with alternating data in the second #CS sequence - for whatever reason I don't know. Reading from this address just works fine. One #RD, one #CS. I tried several options and timings, effect stays the same. CPU Cache is OFF. Has anyone an idea what I am doing wrong here? Thanks in advance!
I generated this init code with CubeMX:
SRAM_HandleTypeDef hsram1;
/* FMC initialization function */
void MX_FMC_Init(void)
  /* USER CODE BEGIN FMC_Init 0 */
  /* USER CODE END FMC_Init 0 */
  FMC_NORSRAM_TimingTypeDef Timing = {0};
  /* USER CODE BEGIN FMC_Init 1 */
  /* USER CODE END FMC_Init 1 */
  /** Perform the SRAM1 memory initialization sequence
  hsram1.Instance = FMC_NORSRAM_DEVICE;
  hsram1.Extended = FMC_NORSRAM_EXTENDED_DEVICE;
  /* hsram1.Init */
  hsram1.Init.NSBank = FMC_NORSRAM_BANK1;
  hsram1.Init.DataAddressMux = FMC_DATA_ADDRESS_MUX_DISABLE;
  hsram1.Init.MemoryType = FMC_MEMORY_TYPE_SRAM;
  hsram1.Init.MemoryDataWidth = FMC_NORSRAM_MEM_BUS_WIDTH_16;
  hsram1.Init.BurstAccessMode = FMC_BURST_ACCESS_MODE_DISABLE;
  hsram1.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_LOW;
  hsram1.Init.WaitSignalActive = FMC_WAIT_TIMING_BEFORE_WS;
  hsram1.Init.WriteOperation = FMC_WRITE_OPERATION_ENABLE;
  hsram1.Init.WaitSignal = FMC_WAIT_SIGNAL_DISABLE;
  hsram1.Init.ExtendedMode = FMC_EXTENDED_MODE_DISABLE;
  hsram1.Init.AsynchronousWait = FMC_ASYNCHRONOUS_WAIT_DISABLE;
  hsram1.Init.WriteBurst = FMC_WRITE_BURST_DISABLE;
  hsram1.Init.ContinuousClock = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
  hsram1.Init.WriteFifo = FMC_WRITE_FIFO_DISABLE;
  hsram1.Init.PageSize = FMC_PAGE_SIZE_NONE;
  /* Timing */
  Timing.AddressSetupTime = 4;
  Timing.AddressHoldTime = 4;
  Timing.DataSetupTime = 1;
  Timing.BusTurnAroundDuration = 8;
  Timing.CLKDivision = 2;
  Timing.DataLatency = 5;
  Timing.AccessMode = FMC_ACCESS_MODE_A;
  /* ExtTiming */
  if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
    Error_Handler( );
  /* USER CODE BEGIN FMC_Init 2 */
  /* USER CODE END FMC_Init 2 */
The test code that writes one half word to the base address
 for(;;) {
   *((uint16_t*)0x60000000) = (uint16_t)0x5555;
   HAL_Delay(100);
This compiles into:
                 _writeReg:
  0x2401'3104: 0xb570         PUSH      {R4-R6, LR}
  0x2401'3106: 0x0004         MOVS      R4, R0
  0x2401'3108: 0x000d         MOVS      R5, R1
  0x2401'310a: 0x0016         MOVS      R6, R2
                 ??_writeReg_0:
  0x2401'310c: 0xf245 0x5055  MOVW      R0, #21845              ; 0x5555
  0x2401'3110: 0xf05f 0x41c0  MOVS.W    R1, #1610612736         ; 0x6000'0000
  0x2401'3114: 0x8008         STRH      R0, [R1]
    HAL_Delay(100);
  0x2401'3116: 0x2064         MOVS      R0, #100                ; 0x64
  0x2401'3118: 0xf7fc 0xfde2  BL        HAL_Delay               ; 0x2400'fce0
  0x2401'311c: 0xe7f6         B.N       ??_writeReg_0            ; 0x2401'310c
The signals look like this:
 0693W00000FDQTAQA5.pngis alternating with this
Microman
For all who came to this topic because they have experienced the same issue, here is the fix:
"Remap FMC so that in MPU it is Device area"
https://community.st.com/s/question/0D53W00000HwJ8JSAV/stm32-fmc-sram-16bit-write-4-tims-a-call
Maybe ST could add a note in the next revision of the reference manual that users have to reconfigure the MPU to use 16 bit access to external memory devices.
Microman
It seems the solution link gives me "access denied". Has this page been moved?
