The usb can not init OK, and error in USB_DevInit.
jimmy_cheng
Visitor
USB_FlushTxFifoc & USB_FlushRxFifo API flag USB_OTG_GRSTCTL_TXFFLSH & USB_OTG_GRSTCTL_RXFFLSH can not clear when set.
1 REPLY 1
FBL
Hi @jimmy_cheng
Typically, you have an issue to initialize your USB PHY consequently core init. Check you clock configuration, your sequence to configure the PHY.
