The behavior of the gpio pin when powering on and powering off
2020-04-28 04:09 PM
This question may applied to the whole STM family and maybe pure hardware related, but I expect someone can give some clues.
- May I safely assume the gpio pins are high impedance when powering on?
- If I set pin to output, and output a high. Then, the power supply goes down. I expect the output will track the power supply till some point, that the pin can't retain output state anymore. Am I right? If so, when the point will occur, what's the supply voltage then?
- Similar to above, but this time set the pin low. What's the point I can't safely assume the pin is low?
Thanks.
GPIO-EXTI
STM32H7 Series
2020-04-28 05:33 PM
Most pins are in input mode, which is floating. Some pins associated with JTAG/SWD are not floating.
Yep. The brown-out reset (BOR) is configurable and kicks in at various states, but generally around 1.8V. Once in reset, pins are in their reset state.
Same as above.
2020-04-28 05:33 PM
Same as above.
2020-04-28 11:22 PM
Check the reset values of the GPIO registers in the reference manual to see which pins have pullup or pulldown enabled.
