TFT 16bit connections
Not applicable
Hello Everyone
I want connect stm32F LCd controller to TFT lcd but 16 bit  because I have lack of pins . how should I connect the RGB pins of STM32 to RGB pins of the LCD ?
In case I use the LTDC contrller in 16bits , Can I use the unused pins  RGB of the controller  for other  fucntions ?
Thank you in advanced
mƎALLEm
Which STM32 part number?
Please review the tips on how to post a thread in this community: https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228.
You can refer to that application note: https://www.st.com/resource/en/application_note/an4861-introduction-to-lcdtft-display-controller-ltdc-on-stm32-mcus-stmicroelectronics.pdf
Yes.
7 REPLIES 7
mƎALLEm
Yes.
Not applicable
Hello
We use STM32F429, and STM32UF9
Sami
Ok. edited the post then .. PS: There is no STM32UF9 part number.
As said review the application note AN4861.
Not applicable
Thank you ,
Should I connect the floating pins of the LCD to ground ?  or leave them floating ?
What do you mean by "floating pins of the LCD"?? RGB pins? in that case why? You said:
"In case I use the LTDC contrller in 16bits , Can I use the unused pins  RGB of the controller  for other fucntions ? "
So I understood you will use LCD with less pins of what available on STM32.
Not applicable
Hello
The TFT  lcd  is 24 bits RGB ; I will use 16 bit  only and I will connect the  MCU STM32 to LCD as you suggested  in  AN4861
But my question
What about the unused   pins now in the lcd , I have 8 data pin of the lcd not used ,  should I leave them floating ?
or connect them to ground?
Thank you
I think you need to connect them to the GND but you need to refer to the datasheet of the LCD.
