2021-07-26 09:17 AM
In dual ADC mode, the bit DMAEN is invalid as the doc said but in the below screenshot it is describing that the DMACFG bit in ADCx_CCR is effective only when DMAEN = 1.
Please see the below snippets from the document.
Need help from you whether I am right or not? And I just want to know proper procedure to do.
2021-07-28 01:41 AM
Hello @Community member ,
This is a typo: this should be MDMA instead of DMAEN
In the ADCx_CCR DMACFG, it should indicate “effective only when MDMA[1:0] != 0�?.
I have raised the error internally for fix .
Thanks for your contribution.
Imen
2021-07-27 04:49 AM
I will check and get back to you as soon as possible .
Imen
2021-07-28 01:41 AM
Imen
