STM32U0 Startup current
JCard.3
Hi @Amel NASRI,
Thanks for sharing the info here.  I'm really interested in low power MCUs.  I do have one question:  where can I find information about the startup current draw of this part?  The datasheet has very good documentation on the supply current requirements in each low-power modes (6.3.5 Supply current characteristics).  But on an energy-harvesting system, the startup current might also be limited.  On my STM32L0 based designs, I noticed that the startup current was an order of magnitude higher than when running in low-power mode.  Is this also the case on the new STM32U0?  Is that documented anywhere?
Thanks!
Javier
3 REPLIES 3
Amel NASRI
Question originally asked a a follow-up of New possibilities for the ultra-low power segment!
Better to discuss it separately.
-Amel
Thanks @Amel NASRI for curating the post.  Should I tag someone in particular for this question?
Cheers,
Javier
Hi @JCard.3 ,
we are aware of your request and will come back to answer it.
-Amel
PS: Internal tracking number of the request: 199335.
