STM32L496 LED problem
Ratheesh
Hello everyone!
Currently I'm working in STM32L496ZG-p Nucleo board, I have written code for both MCU specific header file and Driver specific header file and I started to build a simple project to make a LED blink. But I haven't got the proper result. As I altered the code with different ports and with different pins, then also I didn't get the result.
2 REPLIES 2
STTwo-32
Hello @Ratheesh
I suggest you try busing this example. Don't forget to use the last version of ide and Cube Firmware.
Best Regards.
STTwo-32
SofLit
As you are writing your own GPIO driver and facing some issues start by inspiring from Cube HAL from here.
Refer also to this example for a complete application.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
