2024-01-05 03:51 AM
STM32L476 data sheet Rev 8 talks in 3.15 about "Down to 18.75 ns sampling time" while table 77 only lists a minimal 31.25 ns minimal sampling time. Is 18.75 ns sampling time possible and with what setting?
2024-01-12 05:36 AM - edited 2024-01-12 05:36 AM
Hello @Uwe Bonnes ,
Thank you for bringing this issue to our attention.
After checking internally with @InsignificantBit "18.75 ns sampling time" isn't correct.
The minimum sampling time is calculated as follows:
2.5 cycles / 80 MHz (max ADC frequency) = 31.25ns
So table 77 is correct, but this sentence “Down to 18.75 ns sampling time" is not correct.
Internal ticket number: 170685 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
2024-01-05 09:36 AM - edited 2024-01-12 05:10 AM
The 31.25 ns is indeed the shortest sampling time possible. The mention of 18.75 ns in the datasheet is indeed an error.
My previous reply was incorrect. I apologize for any inconvenience.
18.75 ns sampling time is possible, the 31.25 ns is the lowest time for which we provide some specifications in the datasheet.
2024-01-05 10:21 AM
How is it possible? SMPR registers have no published setting for a single sampling cycle. Or do you mean to overclock the CPU by 250 %.
Hello @Uwe Bonnes ,
Thank you.
Kaouthar
