2021-09-06 1:03 PM
Can I use a external flash in qspi mode connected to qspi peripheral bank 2 ?
I wan to test 2 things:
I use bank2 because in lqfp 100 package i had direct and close connection to external flash.
2021-09-06 4:00 PM
I believe that it can, ultimately depends on which pins you used.
Ok, so test those things.
