[STM32H743VITx] PWM Configuration
KhangRtR
Dear Experts,
I am expecting to configure the PB5 of the STM32H743VITx as a PWM signal in order to trigger some external devices :
I would like to generate a less-than 30Hz/60Hz pulse with variable duty cycle. Could you help or share some examples in order to archive this within the CubeMX configuration, please ?
Thanks in advance,
Best Regards,
Khang
1 REPLY 1
Sarra.S
Hello @KhangRtR
You can follow Getting started with TIM - stm32mcu, to understand how to configure timer's parameters in STM32CubeMX depending on your timer clock.
