STM32H743 RTC Clock configuration failure
anilgayakwad
I'm working on STM32H743BIT6, It is in production phase. During flashing the software, it is failed to configure LSE crystal with internal RTC enabled. out of 50 boards 2 board got failed.
During debug it is observed that the RTC clock configuration is getting failed.
Kindly support us for resolving the issue
Thank You
Anil Gayakwad
1 REPLY 1
SofLit
Not sure what do you mean by "During flashing the software, it is failed to configure LSE crystal with internal RTC enabled". ?
Do you mean that the RTC failed to be configured at your application startup? and what is the symptom? enable to write to a register or what?
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
