STM32F411 Timer not producing fixed PWM duty cycle at output timer channel.
‎2024-02-29 12:27 AM
I am using the STM32F411 MCU and i am trying to generate PWM signal with fixed dutycycle and frequency.
clock configuration and timer settings is attached below.
When I set the PWM frequency to 10KHz and the duty cycle to 50%, I get the output as 10 KHz frequency and the dutycycle toggles between 50.00% and 49.97%. When setting PWM frequency to 40KHz and duty cycle to 50%, I get output as 40 KHz frequency and dutycycle toggles between 48.00% and 47.97%.
Program code:
Could you please explain why getting like this?
Thank you
STM32F4 Series
‎2024-02-29 01:28 AM
Hello @vrindar,
I would check the clock source, but since you're using HSE, I don't think that would be the problem
Try to get the prescaler to zero, and do all the division in the period
‎2024-02-29 01:02 PM - edited ‎2024-03-01 01:01 AM
Does the program run otherwise, e.g. if you blink a LED (toggle an output) with a simple loopdelay in main loop, does it blink?
Read out and check/post content of TIM and relevant GPIO registers.
[EDIT] sorry I misread the question [/EDIT]
‎2024-02-29 08:26 PM
Hello @Sarra.S
I tried the same in the Evaluation board(STM32F429ZI) using HSI but got the same variation in the duty cycle.
‎2024-03-01 02:01 AM
Hi @vrindar ,
If you set prescaler so that timer's counter clock is 1ms, and you set ARR so that PWM frequency is 40kHz, the period is 1/40kHz = 25ms i.e. ARR=25-1 and the granularity of pulse width setting is 1ms. If you want 50% PWM, the calculation you made above (i.e. ((PWM_Dutycycle*Auto_Reload_Value)/100) = (50*25)/100 =1250/100 = 12 (notice the rounding in integer division), i.e. the pulse is ON for 12 ms and off for 13ms. That's 12ms/25ms=48% (as consequence of the rounding). With 1ms granularity (i.e. prescaler set to 72-1) you can't set the PWM more precisely; if you'd set CCRx to 13, you'd have 13ms long pulse i.e. 13ms/25ms = 52% ratio.
The solution is, as @Sarra.S said above, not to set prescaler to result in 1ms timer counter clock. As she said, simply set prescaler to 0, and then for 40kHz PWM you'll have ARR=(72 * 25) - 1, and the granularity is 1/72ms.
‎2024-03-01 12:16 PM
@vrindar wrote:...the dutycycle toggles between 50.00% and 49.97%....
How did you measure that values ? Did you just read these values from oscilloscope or logic analyzer "automatic measurment" ?
