2015-05-31 11:51 PM
2015-06-08 09:31 AM
Can you please indicate which toolchain and STM32CubeMX versions you are using? Thanks.2015-06-08 09:56 AM
One of the GNU chains.
It was discussed recently in another thread, can't find it right now.It should be aligned, at the very least 4-byte to the top of memory, as it predecrements.ARM has mentioned an 8-byte alignment in the past, not sure that's rigorously enforced, and perhaps more salient in CPU/FPU situations where a 64-bit load/store is used.2015-06-08 10:01 AM
Here's one from a year ago
This perhaps the one I had in mind2015-06-08 10:33 AM
2015-07-01 04:43 AM
Thank you for your feedback. This problem will be resolved in next CubeMX release 4.9.
