STM32F4 ADC multiple channel read using Interrupt WITHOUT DMA
‎2022-02-12 7:04 AM
I want to scan 14 channels of adc1 in scan mode using interrupt. I need it to be with interrupt not DMA and I know how to use DMA so please don't tell use DMA! :D
The problem is that HAL_ADC_ConvCpltCallback runs only once! I will attach my code here. any ideas and help is really appreciated.
my adc init is:
* @brief ADC1 Initialization Function
* @param None
* @retval None
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 14;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_144CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = 2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = 4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = 5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
sConfig.Rank = 6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
sConfig.Rank = 9;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = 10;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 11;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = 12;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_14;
sConfig.Rank = 13;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_15;
sConfig.Rank = 14;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* Enable DMA controller clock
static void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
/* DMA interrupt init */
/* DMA2_Stream0_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
* @brief ADC MSP Initialization
* This function configures the hardware resources used in this example
* @param hadc: ADC handle pointer
* @retval None
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
if(hadc->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_ADC1_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/**ADC1 GPIO Configuration
PC0 ------> ADC1_IN10
PC1 ------> ADC1_IN11
PA0-WKUP ------> ADC1_IN0
PA1 ------> ADC1_IN1
PA2 ------> ADC1_IN2
PA3 ------> ADC1_IN3
PA4 ------> ADC1_IN4
PA5 ------> ADC1_IN5
PA6 ------> ADC1_IN6
PA7 ------> ADC1_IN7
PC4 ------> ADC1_IN14
PC5 ------> ADC1_IN15
PB0 ------> ADC1_IN8
PB1 ------> ADC1_IN9
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
/* ADC1 interrupt Init */
HAL_NVIC_SetPriority(ADC_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(ADC_IRQn);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
* @brief ADC MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* hadc)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ADC1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5);
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7);
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1);
/* ADC1 interrupt DeInit */
HAL_NVIC_DisableIRQ(ADC_IRQn);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
my callback is :
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
internal_ADC1[adc_index] = HAL_ADC_GetValue(hadc);
if (adc_index < 12)
adc_val[adc_index] = (float)(internal_ADC1[adc_index] * 5.14) / 4095.00;
else if (adc_index == 12)
adc_val[adc_index] = (float)(internal_ADC1[adc_index] * 36.3) / 4095.00;
else if (adc_index == 13)
adc_index++;
if(adc_index == 14)
adc_index = 0;
HAL_GPIO_TogglePin(LED3_GPIO_Port, LED3_Pin);
and I call
HAL_ADC_Start_IT(&hadc1);
only once before while(1).
as I configured the adc in scan mode and continuous mode, I expect that at least I jump to my ISR 14 times but on debug it shows that it calls only once.
thanks in advance.
ADC
STM32F4 Series
‎2022-02-12 7:25 AM
Well good luck with that..
Perhaps use the Injected model/method.
‎2022-02-12 7:25 AM
Maybe
AdcHandle.Init.EOCSelection = ADC_EOC_SEQ_CONV;
‎2022-02-12 7:36 AM
Perhaps, but single call suggests it is flagging an error.
One might need to slow the sample rate to a manageable level.
Break-pointing on a human time scale would also be prone to fail completely.
‎2022-02-12 8:00 AM
This causes having the last converted channel on data register and losing the others.
‎2022-02-12 8:07 AM
my APB2 Clock is 72 Mhz and because of 144 cycle sampling I've chosen I expect it that Tconv = (144+12) * 1/72MHz = 2.1 microSeconds for each convertion and 2.1*14 = 28.8 u sec. is it right?
‎2022-02-12 8:23 AM
Are you sure that 144+12 cycles is not enough to do the processing here?
‎2022-02-12 8:27 AM
Is your LED togling on scope ? On LED you see no change on this speed.
Maybe try
Too check if float calculation dont hardfault or took long time... you need FPU and setup it...
‎2022-02-12 8:31 AM
I didn't get your point. its the conversion time of adc based on stm32f4 reference manual. there is no processing at all. it's not working! :)))
‎2022-02-12 12:51 PM
Code isn't executed infinitely fast. There is processing in the IRQ handler. If that doesn't finish before the next conversion, the next event can't fire and you can't read out DR fast enough, which stops the ADC and sets the OVR error bit.
