2024-04-27 08:29 AM - edited 2024-07-10 03:39 AM
I have used software control GPIO simulate parallel interface to successfully receive data, but how to faster, I used timer to trigger DMA, but the effect is very bad.
About: 1-1.5 FPS
2024-04-27 03:02 PM
It's a very old part, couldn't you just use a more modern one with DCMI and F(S)MC memory?
Band width of UART and USB FS also likely to be significantly limiting on frame rates.
2024-04-27 10:44 PM
yes, I just want to know what is the maximum frame rate that can be optimized
