stm32f0 adc dma multi channel problem
‎2022-04-11 10:08 PM
1. ADC setting
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc.Init.Resolution = ADC_RESOLUTION_12B;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc.Init.LowPowerAutoWait = DISABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = ENABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc.Init.DMAContinuousRequests = ENABLE;
hadc.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
if (HAL_ADC_Init(&hadc) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
Error_Handler();
2.DMA Setting
hdma_adc.Instance = DMA1_Channel1;
hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_adc.Init.Mode = DMA_CIRCULAR;
hdma_adc.Init.Priority = DMA_PRIORITY_VERY_HIGH;
if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
Error_Handler();
3. DMA START
unsigned short Test_adc[6];
HAL_ADC_Start_DMA(&hadc,(uint32_t *)Test_adc,6);
Results of testing with ADC DMA configured in the Cube IDE
Only the first value is sampled and entered.
Please tell me what should be corrected to convert correctly.
- Labels:
ADC
DMA
STM32F0 Series
‎2022-04-17 2:53 AM
"Your ADC & DMA are well configured. Please make sure that MX_DMA_Init(); is called before MX_ADC_Init();
It should work like that."
in my code dma is defined before adc but still sample from dma adc once and i set dma circular mode i not set dma normal mode
‎2022-04-13 1:39 AM
Hello @superK​,
Best Regards,
Gwénolé
‎2022-04-17 2:53 AM
