STM32CubeMx removes all files from folder during regeneration when Toolchain changed
John Smith
Posted on July 04, 2018 at 14:05
DAHMEN.IMEN
SIRY.Marc.001
Steps to reproduce.
Create new STM32CubeMx project and generate sources as usual:
- Open STM32CubeMx -> New project -> Select MCU (STM32F030K6 in my case)
- Project -> Settings -> _some_project_name_entered_
  Note:  EWARM toolchain stays as it was by default
- Project -> Generate code
- Close STM32CubeMx
- Open STM32CubeMx project from last saved folder
- Make some changes in pinout
To this moment all works fine, but when I want to change toolchain to
TrueSTUDIO and generate project to same folder all files in folder are deleted
and I losts all my changes in main.c and other files:
- Project -> Settings -> Toolchain: TrueSTUDIO (Generate under root unchecked)
- Ok button press and I get message ''This Project File (cube_regen_test.ioc)
  already exist in chosen folder. Overwrite this file by this new Project?''.
- Ok button pressed on Overwrite confirm messagebox
Expected behaviour on regeneration:
- All user file stays untouched
- Cube generated files changed accordinly to new configuration and users code
sections keeps
STM32CubeMx Version 4.26.00690X0000060CARQA2.png0690X0000060CBUQA2.png0690X0000060CBPQA2.png
null
2 REPLIES 2
Imen.D
Posted on July 04, 2018 at 15:06
Hello
smith.john
I rasied your issue internally for check and we come back to you as soon as possible.
With Regards,
Imen.
Imen
Houda GHABRI
Posted on July 05, 2018 at 14:32
Hello
Thanks for your feedback.
Issue will be resolved in next STM32CubeMX release (4.27.0).
Best regards,
Houda
