STM32CubeMX for STM32L4 Discovery kit IoT node (B-L475E-IOT01A)
‎2017-09-20 6:47 PM
I would like to generate the code by using STM32CubeMX for STM32L4 Discovery kit IoT node (B-L475E-IOT01A).
But I don't see the STM32L4 Discovery kit IoT node in the Boards List.
Could you suggest for me?
Thank you
‎2018-01-25 6:26 AM
krekelberg.greg
,Sorry for my long delay to answer.
4.24 has been released.
Kind regards
Sirma
‎2017-09-21 5:17 AM
Do it at a chip level?
The V1.8.0 release does have a number of examples for the board, these were written outside of CubeMX, probably due to non-trivial complexity.
‎2017-09-21 11:10 AM
Thank you very much
‎2017-09-22 6:21 AM
Hi
Piwatpakapol.Rat
‌,We will keep you informed about the release date of CubeMX version that will support STM32L4 Discovery kit IoT node B-L475E-IOT01A.
Meanwhile, you can start building your project selectingSTM32L475VGT6 as device as suggested by Clive One.
-Amel
‎2017-11-08 9:26 AM
Hello
Piwatpakapol.Rat
,I confirm you that IoT noards will be supported in CubeMX4.
Its release is planned by end of the year.
Kind regards
Sirma
‎2018-01-18 6:54 PM
Hi Sirma,
Any word on when 4.24 will be released?
Thanks,
Greg
‎2018-01-25 6:26 AM
krekelberg.greg
Kind regards
Sirma
