STM32 won't start without physical reset.
dodonny
My mcu is STM32L476RGTx and I experiencing very strange behaviors to make my cpu start.
This mcu is on pcb I designed myself.
My boot0 pin is shorted to GND
And the reset pin pulled up to VCC.
I can program my chip with my st link (updated to the last version) an after each programming my chip is starting up as expected.
But as soon as I tried to make it boot from cold start it won't start. I have to manually press reset button and after that, it run as expected.
It append what ever i use as supply. 3V3 from programmer, 3V3 from local switching supply (LM43602)...
For the moment i do not use the 8mhz quartz on board.
Have you any idea I did not check yet or they're is any parameter that could prevent my mcu to run my program from flash but make it run as soon as I create a true reset event ?
Maybe is it BOD ? But how could I check that ?
anyway, Thanks for your help.
19 REPLIES 19
Piranha
Chief II
Another board with a wrong NRST schematic not following AN4555?
> ffbff8aa
> That's BFB2 set, isn't it?
Yes, it is, just fr testing purpose. Back to unchecked after that.
> Is your connection from STLink to target short (up to 15cm) and, if using a flat cable, with ground in between the signal lines?
I'm using 2 wire, SWCLK and SWIO with GND
The issue is the same with or without the debugger plugged.
I'm using scope today to check signals
I'm reading it right now. to Confirm if I meet the requirement or not.
dodonny
Here is a typical power up voltage trace. On top (RED one) you have the VDD signal and the bottom the RST signal voltage. Still not booting.
dodonny
But if the ST-link is connected to the board and connected to usb (but without any software launched). The firmware start alone.
So make a cold start, and after connected the debugger -> the firmware not start. And this is the state, still in the boot loader zone :
> stm32l4x.cpu curstate
running
> halt
target halted due to debug-request, current mode: Thread
xPSR: 0xa1005800 pc: 0x1fff495e msp: 0x200030a8
> reg
===== arm v7m registers
(0) r0 (/32): 0x48000000
(1) r1 (/32): 0x89800000
(2) r2 (/32): 0x00010100
(3) r3 (/32): 0x50000b00
(4) r4 (/32): 0x200007d8
(5) r5 (/32): 0x48000400
(6) r6 (/32): 0x40021040
(7) r7 (/32): 0x48000000
(8) r8 (/32): 0x48000800
(9) r9 (/32): 0xe000e010
(10) r10 (/32): 0x40013000
(11) r11 (/32): 0x40003800
(12) r12 (/32): 0x00000000
(13) sp (/32): 0x200030a8
(14) lr (/32): 0x1fff4947
(15) pc (/32): 0x1fff495e
(16) xPSR (/32): 0xa1005800
(17) msp (/32): 0x200030a8
(18) psp (/32): 0x00000000
(20) primask (/1): 0x00
(21) basepri (/8): 0x00
(22) faultmask (/1): 0x00
(23) control (/3): 0x04
(24) d0 (/64): 0x0000000000000000
(25) d1 (/64): 0x0000000000000000
(26) d2 (/64): 0x0000000000000000
(27) d3 (/64): 0x0000000000000000
(28) d4 (/64): 0x0000000000000000
(29) d5 (/64): 0x0000000000000000
(30) d6 (/64): 0x0000000000000000
(31) d7 (/64): 0x0000000000000000
(32) d8 (/64): 0x0000000000000000
(33) d9 (/64): 0x0000000000000000
(34) d10 (/64): 0x0000000000000000
(35) d11 (/64): 0x0000000000000000
(36) d12 (/64): 0x0000000000000000
(37) d13 (/64): 0x0000000000000000
(38) d14 (/64): 0x0000000000000000
(39) d15 (/64): 0x0000000000000000
(40) fpscr (/32): 0x02000000
===== Cortex-M DWT registers
At the end, I will put a JMP in my boot loader zone to go 0x80000
XD
dodonny
I put a 100uF capacitor between NRST and GND. Take 5 sc to charge. And boot fine with that !
(take care to the base time on the image below. Screen width take 14sc).
Same connection as previous. Top is VSS and bottom is NRST
0693W000006IAZLQA4.pngEDIT: Removed the 100uF capacitor (was only for testing) an removed the 100nF capacitor between NRST and GND and work fine now...
So i'll let it like that.
That was my 100nF capacitor (between NRST and GND) which is the faulty one. Was here to protect RESET button and debonce NRST signal. But seems too big.
dodonny
Without my 100nF capacitor. This is the voltage trace of VDD and NRST
Not so far from the first one. But enough to prevent it to boot.
Is your VDD 5V?
dodonny
Nop, sorry on the scope I plugged the scope lead in my 5V. But I have en 3V3 LDO after that.
doddonny
flag
