static declaration of 'MX_FDCAN1_Init' follows non-static declaration - NO IT DOESNT!
Tobe
Senior III
I got an error, that is actually not true (see pictures). I just used cubemx to change one pin... And now this.
I found the issue:
I searched for that func in my project folder, but since the problem was in a linked file, i could not find the problem. After scrolling through the problems list, i found where it was. And after a further look, it just said to me where it was to be found. It was declared as extern void *** there, so that got a bit confusing.
Got a bit mad, as it looked the compiler was lying.
Edit:
Dang! I could have found it with right mouse click -> declarations.
SofLit
Hello @Tobe
Could you please share your ioc file and which CubeMx version you're using?
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
I found the issue:
Edit:
