SPI + DMA LL library
‎2023-12-11 6:49 AM
Hello.
I am trying to learn about DMA with spi. I tried HAL library which worked fine for me, I tried the LL Examples (stm32L4x) provided in repository which worked fine when i am reading once with loopback. Now i am trying to use a full duplex master spi with transmit via polling and receive via dma. But i am stuck with how to set the receiving part continously ( in a while(1) loop after rx complete callback) with normal mode as i have to set different address each time i am receiving data from an external chip.
Can anyone provide with some suggestion for this?
‎2023-12-11 7:23 AM
Hello @prsh
Have you tried SPI_TwoBoards_FullDuplex_DMA example using circular mode? It should help to ensure continuous transfers.
‎2023-12-11 7:44 PM
Yes tried that but my application needs normal mode only to set receive dma before every data receive.
