I am using STM32L0 and I want to run RTC in my custom board. I using Internal LSI clock for RTC. When I set Alarm for 60 sec it is generated in around 54 sec so i think RTC is running faster . So how can i calibrate it?
‎2021-07-03 10:03 PM
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI
|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_3;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_3;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_I2C1
|RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_USB;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
Ams this ias code of RTC.c
- Labels:
RTC
STM32L0 Series
‎2021-07-04 1:57 AM
LSI is a very imprecise clock source, see datasheet. You can "calibrate" it by changing the asynchronous and synchronous pedalers, but it will never be stable and precise.
‎2021-07-04 2:14 AM
so what is the best option to go with?
‎2021-07-04 2:29 AM
Best option for what?
To maintain real time, you need to use LSE and a 32.768kHz crystal.
If you have a crystal on HSE and you don't want to use some of the low-power modes (in some of which LSI doesn't work either, btw.), you can derive the RTC clock from HSE too.
