[Solved]Problem with Usart Irq
2020-08-28 6:53 AM
Hi at all,
Sometime happens that usart2 irq freeze and HAL_UART_RxCpltCallback isn't called.
From this moment I can send data (I use blocking instruction HAL_UART_Transmit), but don't receive any.
When this happens, HAL_UART_ErrorCallback don't called too.
In this situation, HAL_Receive_IT returns always HAL_BUSY.
I tried to solve calling these instruction when the status is different from HAL_OK:
__HAL_UART_CLEAR_OREFLAG(huart);
__HAL_UART_CLEAR_NEFLAG(huart);
__HAL_UART_CLEAR_FEFLAG(huart);
__HAL_UART_DISABLE_IT(huart, UART_IT_ERR);
huart->ErrorCode = HAL_UART_ERROR_NONE;
Uart2Status = HAL_UART_Receive_IT(huart, (uint8_t *)&ch, 1);
This solution seems to solve for some tries only.
At the moment, when IRQ freeze, to solve the problem, I must to restart device.
The problem is random.
Can you help me?
Thanks.
UART-USART
2020-08-31 1:35 AM
Hi at all,
I probably solved it.
I had used HAL_UART_Transmit instead of HAL_UART_Transmit_IT.
Now (with HAL_UART_Transmit_IT) it seems to work fine.
Thanks at all for help.
2020-08-28 7:47 AM
Break in debugger to understand where it "freeze"
Interrupt Handlers will reenter (tail-chain) continuously if the cause isn't serviced properly.
Have Error_Handler() and HardFault_Handler() output actionable data.
2020-08-28 8:06 AM
Hi clive1 and thanks for answer.
Excuse me, but maybe don't understand your answers.
--> Break in debugger to understand where it "freeze"
I can't break, because my device continue to work fine, with the exception of serial reception.
There isn't a point where software go in loop or similar.
I know only that HAL_Receive_IT returns HAL_BUSY and if I place a breakpoint into HAL_UART_RxCpltCallback this callback doesn't called even though I am receiving data.
About Error_Handler() and HardFault_Handler() I don't understand what you told me :(
Sorry!
2020-08-31 1:03 AM
Dear @SDall.1
If an overrun error is detected, it could prevent further RXNE interrupts to be raised.
Did you implement some specific treatments in the HAL_UART_RxCpltCallback() callback ?
For example, please make sure to not call a long or blocking process in the callback, as the callback is executed within the Interrupt context.
If you execute a Tx operation by calling HAL_UART_Transmit() in HAL_UART_RxCpltCallback(), this means that RX interrupt treatment will last at least longer time than the transmission time. if new characters are received during this time, overrun error might occur ...
2020-08-31 1:35 AM
Hi at all,
