Sleep current
Manoj Hiwarkar
I am using STM32L010K4. I want to reduce the sleep current to 3uA ,But in the datasheet it is mentioned the the minimum sleep current is 1mA with all the peripherals disabled, which is a larg value
2 REPLIES 2
This isn't really a question.
The L0 family has a wide range of low power options, including shutdown modes that consume several microamps. You'll need to determine your program/peripheral needs and choose the best option out of those available.
Piranha
Chief II
Read the AN4445.
