Setting the F407 FSMC WaitSignalPolarity default value
‎2023-10-25 4:26 AM
Hi All,
I have a 407 connected to an FPGA using the FSMC interface.
When I compile my device configuration from ST Cube, the WaitSignalPolarity value in the MX_FSMC_Init routine is always set to: FSMC_WAIT_SIGNAL_POLARITY_LOW. On my system I need this setting to be FSMC_WAIT_SIGNAL_POLARITY_HIGH, but cannot find a way of setting this value through CubeMX.
Has anyone else found this issue or know how to fix it? Its getting a real pain having to manually update the source code before recompiling.
Kind Regards,
Tony
- Labels:
FMC-FSMC
STM32F4 Series
‎2023-11-29 7:13 AM
Further info - I reconfigure the FSMC_BTR1 reg soon after the FSMC is setup. Do you think I should re-configure the Wait signal polarity here too?
// Correct configuration for FSMC BTR1 register.. (Appologies for the incorrect tabulation - your website screws it all up...
FSMC_BTR1 = (0 << 24) | // DATLAT
(5 << 20) | // CLKDIV - 1 doesn't work on the prototype, 5 defo works, but is slow - need to PCB this
// Gives 168Mhz/(5+1) for io clock :- 28Mhz, so 4 clocks for 16 bit word
// 5 clocks for 32 bit!!
// 7 MegAccesses for 16 bit = 14MB/s, 8.4MegAccesses for 32 bit = 22.4MB/s
(0 << 16) | // BUSTURN
(2 << 8 ) | // DATAST - No care for synchronous accesses
(15 << 4 ) | // ADDHLD - No care for synchronous
(15 << 0 ); // ADDSET - No care for PSRAM accesses
Regards,
Toneski
‎2023-12-01 6:14 AM
An internal ticket 167494 has been submitted to update the SVD file to include all BCR bit fields in STM32F4 SVD file and update FMC BCR register.
‎2023-12-01 7:27 AM
Hi @FBL,
Thats great news. Is there anyway that I can access the internal ticket, so that I may watch its progress?
Also, do you know when this might be fixed? The next release maybe?
Thanks for all your help.
Regards,
Toneski
- « Previous
- 1
- 2
- Next »
