RTC Problem
‎2024-01-26 1:37 AM
I use the NUCLEOH563-ZI board and I want to use RTC. I configured the RTC with the LSI clock. I loaded a default date/time. On the other hand, my time does not change...
My Init code :
My source code to retrieve the time
Thank you for your help !
Ghislain
IAR
‎2024-01-26 2:04 AM
Hello @Ghislain_Clement,
Please check if the RTC_TR and RTC_DR registers get updated
Also, you may want to check: STM32CubeH5/Projects/NUCLEO-H563ZI/Examples/RTC/RTC_LSI
‎2024-01-26 2:04 AM
‎2024-01-26 3:06 AM
THANKS ! I found the solution. I initialized the time before the date and it works.
‎2024-01-26 3:12 AM
Great! I guess it turned out to be this gotcha!
‎2024-01-26 3:16 AM
I missed this information ;)
Thanks again !
Ghislain
