2025-12-18 11:40 PM
In RM0316 rev.10, in Table 109. COMP register map and reset values, bit 1 of COMP2_CSR is marked COMP2_INP_DAC, whereas the STM32F303 are not supposed to have this bit (only STM32F301/302x6/8 do) - probably a copy/paste artefact/relict.
Can ST please check/remove.
2025-12-19 6:00 AM
Typo is confirmed in table 109. It will be fixed in the coming revisions of the document.
Thank you for your contribution.
2025-12-19 12:01 AM - edited 2025-12-19 12:44 AM
I will escalate for analysis and eventual fix.
PS: In the section 17.5.2 COMP2 control and status register (COMP2_CSR) bit 1 is reserved.
Internal ticket for follow-up 224127
2025-12-19 6:00 AM
2025-12-19 6:15 AM
