2024-10-01 12:13 AM - last edited on 2024-10-01 02:00 AM by SofLit
Hi
i am using stm32f767IGK6 i am able to write data in nor flash but can't read data of same address.
by use this APIs HAL_QSPI_Transmit(), HAL_QSPI_Receive()
Regard & Thanks,
Naresh
2024-10-01 01:02 AM
Hello @Naresh_ ,
Could you please give more detail about the issue.
Are you read data in memory mapped mode or indirect mode?
Could you please take a look at the errata sheet precisely:
May QSPI_ReadWrite_IT this example can help you.
Thank you.
Kaouthar
2024-10-01 02:13 AM
Your presentation of the problem and the context is inadequate. Try harder as if you're explaining to someone who's not physically watching you code and test the issue.
