2025-01-16 08:20 PM - last edited on 2025-01-20 01:21 AM by Andrew Neil
Originally posted as a comment on the How to write your question to maximize your chances to find a solution article.
Moved to the forum for clarification & better discussion.
How to create programming code based on the information ?
2025-01-16 08:38 PM - last edited on 2025-01-20 01:16 AM by Andrew Neil
Merged from separate thread.
I would like to ask if this device can read input digital and analog signals 5 volts and output 5 volts on and off in milliseconds STM32F412G-DISCO. Who can help create programming code based on information ?
Discovery Development Board, STM32F412ZG, 32bit, ARM Cortex-M4 or any other boards ? Described diagram is available that shows and describes the relation between pulse number and IO pin On/Off
Thanks in advance for your answer !
2025-01-16 08:39 PM
2025-01-17 02:08 AM
Please clarify what you're actually asking for?
The article describes the information you need to give in your post when asking a question.
