2024-08-21 02:39 PM
Hi All!
Following are the proper codes for read and write the password in Micron MT25QL256ABA
READ PASSWORD 27h
WRITE PASSWORD 28h
Write Enable is executed before to write password using 28H, I wait for the flash to be ready by reading the FLAG STATUS register, then I read the password to verify it was written properly.
The problem is that I am reading zeros only, and I do not understand why.
Perhaps, a step is missing, or a step sequence is required. Datasheet is not explaining or giving information about this topic.
As a note, all the operations work as expected. I am able to erase, read/write data, read/write registers, etc, except by the password.
Here is the log:
========== test_write_read_password ==========
========== Read Device ID
Device Id: 0x1019ba20
READ_SECTOR_PROTECTION_REG: 0x0000ffff
READ_GLOBAL_FREEZE_BIT_REG: 0x00000001
READ_VOLATILE_LOCK_BITS_REG: 0x00000000
READ_NONVOLATILE_LOCK_BITS_REG: 0x000000ff
========== Read Password
Password -> DATA 0: 0x00000000, DATA 1: 0x00000000
pwd0 = 0x00000000 pwd1 = 0x00000000
========== Read All Flash Registers
Control Register : 0x00000001
SPI Clock Baud Rate Register : 0x00000010
CS Delay Setting : 0x00000000
Read Capturing Register : 0x00000000
Operating Protocols Setting Register : 0x00000000
Read Instruction Register : 0x00000003
Write Instruction Register : 0x00007002
Flash Command Setting Register : 0x00008827
Flash Command Control Register : 0x00000000
Flash Command Address Register : 0x00000000
Flash Command Write 0 Register : 0x00000000
Flash Command Write 1 Register : 0x00000000
Flash Command Read 0 Register : 0x00000000
Flash Command Read 1 Register : 0x00000000
========== Write Enable
========== Write Password
Password -> DATA 0: 0xC0FFEE11, DATA1: 0xBABECAFF
Flash Command Setting Register : 0x00008028
Flash Command Write 0 Register : 0xc0ffee11
Flash Command Write 1 Register : 0xbabecaff
Flag Status 0x00000081
Flash Command Setting Register : 0x00001870
Flash Command Read 0 Register : 0x00000081
Password -> DATA 0: 0xC000FFEE, DATA1: 0xBABEBABE
Flash Command Write 0 Register : 0xc000ffee
Flash Command Write 1 Register : 0xbabebabe
