Problem with STM32L475 Discovery kit IoT node power supply
DMala.1
Hello, I've just received the STM32L475 Discovery kit IoT node. I connected the board through USB cable to my laptop (the JP4 jumper is connected to 5V_ST_LINK) and the power supply LED (LD5) is blinking. Also the board is not visible from laptop (I have installed the required drivers). What is going on? Is there something else I have to do?
4 REPLIES 4
Make sure not to use a charging cable, these only have power lines, and lack the data lines for connectivity.
Pavel A.
Evangelist III
Are you sure? Have you looked in Devices and Printers, or used a tool such as USBview?
-- pa
Hi, thank you for your answer. The problem seems to be the power supply, that's why the board is not visible. The power supply LED should be on and not blinking. ​
