2020-02-26 07:14 AM
Hi all,
I am working on a STM32F103VEtx MCU. In my firmware I have redirected the printf function to a UART for debugging purposes. When I start running the code, the printf function causes the hard fault handler to hit. Please see the call stack attached below
Thread #1 (Suspended : Signal : SIGINT:Interrupt)
prvGetRegistersFromStack() at stm32f1xx_it.c:109 0x800441a
<signal handler called>() at 0xfffffff9
std() at 0x8007abe
__sinit() at 0x8007b76
printf() at 0x8006dac
main() at main.c:130 0x800400c
It seems like std() function call triggers the hard fault. Please help me to figure out and fix the issue.
Thanks in advance,
Pramod K. G.
2020-02-27 10:12 PM
The runtime library sources should be available where your toolchain (compiler etc) came from.
