printf function call causes hard fault
Pramod K.G.
Hi all,
I am working on a STM32F103VEtx MCU. In my firmware I have redirected the printf function to a UART for debugging purposes. When I start running the code, the printf function causes the hard fault handler to hit. Please see the call stack attached below
Thread #1 (Suspended : Signal : SIGINT:Interrupt)
   prvGetRegistersFromStack() at stm32f1xx_it.c:109 0x800441a
   <signal handler called>() at 0xfffffff9
   std() at 0x8007abe
   __sinit() at 0x8007b76
   printf() at 0x8006dac
   main() at main.c:130 0x800400c
It seems like  std() function call triggers the hard fault. Please help me to figure out and fix the issue.
Thanks in advance,
Pramod K. G.
10 REPLIES 10
Step through and figure out which instruction causes it. The standard printf uses malloc, which may be causing it.
Hi TDK,
Thanks for the response. I already had tried 'step through' the printf function and it was not working for me. ​Hardfault handler was hitting when I do a step in to printf function.
From the NVIC register CFSR, I could see that BFARVALID and PRECISERR are set. Also the content of BFAR is 0.
I tried with increasing the heap and stack but the results were same.​
It is telling you address 0 contains an invalid instruction. But you generally shouldn't be executing at address 0. Is it possible your vector table contains invalid (nullptr) entries and one of those interrupts is being called?
What happens if you disable irqs during the printf call?
Probably linking in the wrong libraries.
Do a disassembly/listing and walk the code.
I'd personally look at the CPU registers and code surrounding the failure.
Likely to be a Read as the fault is precise.
Perhaps a value in a structure or a pointer
Thanks for looking into this issue.
Attaching the disassembly code snippet where issue is happening
         std:
08007ab9:  movs   r3, #0
08007abb:  push   {r4, lr}
08007abd:  mov    r4, r0
08007abf:  strd   r3, r3, [r0]
08007ac3:  str    r3, [r0, #8]
08007ac5:  strh   r1, [r0, #12]
08007ac7:  str    r3, [r0, #100] ; 0x64
08007ac9:  strh   r2, [r0, #14]
08007acb:  strd   r3, r3, [r0, #16]
It seems like hardfault is triggered from the line of code "08007abd:  mov    r4, r0". When clicking the std() function in call stack it is jumping to above mentioned line of code. Attaching the screenshot for more clarification.
A mov won't cause any fault, it's just moving a value of one register to another. It's most likely the next one, storing two words to memory pointed by [r0], which is the first parameter of the function call. So this function is called with a NULL pointer argument.
Get the sources of your C runtime library, and look into it, what could cause it to be called with a NULL pointer.
can you please tell how can I get the sources of your C runtime library?
Ok, but what are the register values?
Betting R0 is NOT aligned and the STRD is failing
Hi Clive1,
Attaching the general purpose resister values
r0   0
r1   4
r2   0
r3   0
r4   -171798145
r5   0
r6   0
r7   12
r8   115200
r9   8
r10   7
r11   536871196
r12   -171798145
sp   0x2000017c <__global_locale+64>
lr   0x8007b77 (Hex)
pc   0x8007abe <std+6>
xPSR   0x61000000 (Hex)
msp   0x2000013c <__global_locale>
psp   0x0
primask   0
basepri   0
faultmask   0
control   0  .
I am seeing weird behavior with sprintf also.
Eg.
sprintf(buff, (const char *)"sprintf testing\n\r"); => No issues
sprintf(buff, (const char *)"sprintf %d\n\r",10); => Hitting hard-fault
You said "Probably linking in the wrong libraries", can you please explain?
My Linker flags => -specs=nosys.specs -specs=nano.specs -u _printf_float
