NUCLEO-F030R8 Default ADC Value 1.65V(2035)
Proteus
When I activate ADC channel I'm getting 2035 value without any connection from ADC channels, I changed several channel
  HAL_ADC_Start(&hadc);
    HAL_ADC_PollForConversion(&hadc, HAL_MAX_DELAY);
    raw = HAL_ADC_GetValue(&hadc);
		  // Convert to string and print
    sprintf(msg, "%hu\r\n", raw);
    HAL_UART_Transmit(&huart2, (uint8_t*)msg, strlen(msg), HAL_MAX_DELAY);
7 REPLIES 7
That is OK, unconnected ADC input doesn't mean there is 0V on it.
Connect input voltage. Observe required impedance of the voltage source versus sample time, see datasheet.
Proteus
I thought there is fail on MCU after I tried same code on F4Disco Board when ADC unconnect I got 0 value
Do you mean float voltage ?
Thanks,
Proteus
I pulled down ADC channel with 10K resistor , there is no affect I couldn't find graph on datasheet
Did you check external connections of the associated GPIO pin on the F030 Nucleo board ?
Yes of course , I tried several ADC channels , When I activate channel 1,65V appear on pin
Deactivate channels are 0V
> I pulled down ADC channel with 10K resistor , ...
Connect it directly to GND - if you are sure there are no other external connections.
Any pull-up/pull-down resistor should be less than the recommended ADC input impedance.
I do not trust the Cube/HAL code either.
Did you check the GPIO/ADC register settings, and the raw conversion results ?
Proteus
When I connect to ADC VCC or GND Im getting 4035 or 0 values
I checked ADC settings everything seems to be normal
I changed FW package version
static void MX_ADC_Init(void)
  /* USER CODE BEGIN ADC_Init 0 */
  /* USER CODE END ADC_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC_Init 1 */
  /* USER CODE END ADC_Init 1 */
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN ADC_Init 2 */
  /* USER CODE END ADC_Init 2 */
Thanks,
