no definition for ''__iar_data_init3''
life758
Posted on November 20, 2015 at 14:14
Hello everybody
I want to declare a vector to save data on it (in assembly code).
I use this declaration:
      SECTION MYDATA:DATA (2)
        DATA
Result DS8   3 ;  allocates space (3 bytes)
When I compile, IAR give me this error:
Error[Lp001]: no definition for ''__iar_data_init3'' [needed to initialize section MYDATA (asm.o #6)]
Anyone have any idea how to fix this?
regards
Amel NASRI
Posted on November 26, 2015 at 17:14
Hi engkyr,
If you didn't yet find a solution for this issue, I suggest you describe it in
https://www.iar.com/support/#%21?tab=resources
-Mayla-
life758
Posted on November 27, 2015 at 11:55
Thanks Mayla,
At the end I didn't use any directive. I did it ''manually''
