2022-04-06 01:37 PM - last edited on 2025-02-17 04:42 AM by Andrew Neil
I just installed Atollic TrueStudio on a new PC. I am getting eclipse-related errors when I try to run the program. I have attached the log.
The first few lines of the log are below. full error log is attached
!SESSION 2022-04-06 15:16:19.728 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.atollic.truestudio.productmanager 1 0 2022-04-06 15:16:20.978
!MESSAGE Loading product manager
!ENTRY com.atollic.truestudio.productmanager 1 0 2022-04-06 15:16:20.982
!MESSAGE OS info: Windows 10, 10.0, x86
!ENTRY org.eclipse.osgi 4 0 2022-04-06 15:16:21.056
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (176).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
2022-04-06 01:55 PM
The installation resources guide says 64 bit windows required for installation on W8 and W10. The log shows W32.
Cheers, Hal
2022-04-06 01:55 PM
Cheers, Hal
