2021-09-07 3:59 PM
I have a low frequency (~1 kHz), low duty cycle signal that I'd like to capture rising edges of. What's the minimum width of those pulses to capture them using a timer in input capture mode?
I see there's a programmable digital filter there, in terms of fDTS and ***_INT, and that the latter is the respective APB bus clock (but divided by no more than 2 from SYSCLK). But what dictates fDTS?
2021-09-07 4:48 PM
TIMCLK = APBCLK *2 or *1 depending on the APB divider
fDTS = TIMCLK / ClockDiv field for the TIM, ie CKD bits in TIMx_CR1
2021-09-07 4:48 PM
2021-09-07 4:55 PM
Perfect, that's what I was missing. Thanks for the help.
