2021-10-04 01:59 PM
2021-10-04 03:03 PM
Generally they have favoured parts with an FPU, ie CM4, CM7.
Surely they have a website, and presence, could you not check there?
2021-10-04 03:48 PM
https://micropython.org/stm32/
Looks to have CM0 versions. You might perhaps review the build options/settings. Perhaps take the F4 build and change the target to a Cortex-M3 without FPU, that way it would build with appropriate instructions.
2021-10-04 07:29 PM
Zephyr OS has jerryscript and micropython support as "task", check the supported mcus there...
2021-10-05 03:52 AM
Hello Skund.1, unfortunately,
ST does not support officially the STM32F2 with µPython.
ST support only STM32WB55 with Micropython for the moment.
Please have a look to the Micropython community https://micropython.org/download/stm32/, maybe they plan to support the STM32F2?
If you need to use Micropython on our product, we will pleased to support you on STM32WB
Michael
2021-10-13 06:49 AM
Hi Michael,
In our application we want to use Micropython in Virtual Machine.
In "STM32 and STM8 embedded software solutions" document I found this
Based on the above picture we should be able to use it on F4, F7 and L4/L4+ series.
What's the reason for not supporting on STM32F2 series, is it to do with memory issue or something else?
Siva
